Knowing your system is one of the most important things that you can do to make sure that your computer stays free of trouble and runs at its optimal performance level. Just like keeping an eye on the level of oil in your car or how much air is in your tires, knowing your computer system will let you prevent smaller problems from turning into larger ones. In this article, we will discuss the major and most important parts of your computer system. We will tell you where to find out what they are, and what that might mean to you. In order to help out, we've developed this handy System Data Sheet that you can download and print out to record all of your system information on. This way, if you need to call Technical Support, either EVGA.com's or another company's, you will be well prepared in advance. |
The Motherboard |
![]() Not all motherboards
are equal, some are better designed and built than others, and many problems in
a computer system (even graphics problems) can be traced back to a problem that
has its roots on the motherboard. The main information that you will want to know
about your motherboard is: the name of the manufacturer, the model number of the
motherboard (as used by the manufacturer), the BIOS version that is on your motherboard,
and the location of the motherboard manufacturer's website - in case you need
to get support or updated files from them. |
The Manufacturer |
In
many cases this is a very simple thing to determine. Simply look at your motherboard
box or manual and the manufacturer's name should be clearly visible. If you have
a computer system that is made by a company like Gateway or Dell, you can get
this information from their websites by looking up your system model number with
them.
In some cases though, the motherboard manufacturer chooses not to include their name in any of the materials. There can be a variety of reasons for this and it does not automatically mean that they have a bad motherboard. But it does mean that you will have a little work ahead of you. Here are some handy ways that you can help to determine your motherboard manufacturer if it is not immediately evident:
The Motherboard Model |
Your motherboard
model is important to know because it will help define for both you and any Tech
Support personnel that you contact exactly what the capabilities, strengths, and
weaknesses of your motherboard might be. Very often technical information is listed
by the motherboard model number that is impacted by it so this will help speed
up how quickly you can get your answers. And lastly, your manufacturer will list
updates and FAQs (Frequently Asked Questions) but the motherboard model, so it
is vital to have it in order to get accurate information.
Getting your motherboard
model is very easy - as a matter of fact, you will be able to get your motherboard
model information at the same time and in the same manner that you get the motherboard
manufacturer's name. Everything that applies to finding the motherboard manufacturer
(from above) applies to getting the model number. |
The Motherboard BIOS |
BIOS stands for
Basic Input Output System - and in many ways acts like a very basic tiny operating
system that is stored on a memory chip on your motherboard. When your computer
first powers up, the BIOS is what allows it to begin operating long enough to
load a more powerful operating system (like Microsoft Windows 98, or even Linux)
that then takes over control of your computer. Because changes get made to this
program as time goes by (new features are added, older features are made more
efficient, etc.) it is important to know what version of your motherboard BIOS
is being used on your computer's motherboard.
One very important thing to remember is that motherboard BIOS is not interchangeable. Every single motherboard model from every single motherboard manufacturer has its own BIOS that was written for it - and these BIOS programs will not work on any other type of motherboard, even different models from the same manufacturer. So, if you need to upgrade your motherboard BIOS, you need to make sure that you get the BIOS program that is for your motherboard specifically, otherwise you can render your motherboard inoperable. You can determine your motherboard BIOS version by watching when your computer boots up. Usually it will display the BIOS version and date just above the area where the memory is counted at boot up. If you are having
trouble finding the BIOS version this way, there are several helpful programs
and tips that can help you located on the website we mentioned above, Motherboard
Homeworld. You can also contact your vendor or manufacturer for assistance
in locating your BIOS version. |
The Manufacturer's Web Site |
After
you have found all the information above, you've probably already found out about
the manufacturer's website. But if you haven't, you should. Motherboard
Homeworld maintains an extensive directory of motherboard manufacturer's websites,
with handy and easy ways to search for them.
You should look at your motherboard manufacturer's website at least once in a while as it may contain important information about upgrades, drivers, new BIOS, and important problem solving FAQs. |
Other Sections of Know Your System |
Knowing
Your System Part I: The Motherboard
Knowing Your System Part II: The Motherboard Chipset |
