EVGA 1000, 850, 750 and 650 GQ Power Supplies
Introducing the ultimate value in the EVGA Power Supply lineup; the GQ series. These power supplies take some of the best features from EVGA’s award winning power supply lineup, like EVGA ECO fan mode for near silent operation, Japanese Capacitors, and a highly efficient design, at an excellent value. These new power supplies are 80 Plus Gold rated and offer an outstanding 5 Year Warranty that’s backed by world class EVGA support.
The EVGA ECO mode feature ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
90% efficiency or higher under typical loads and 100% of the highest quality Japanese brand capacitors ensure long-term reliability.
Semi-modular design allows you to only use the cables you need, helping to improve case airflow, eliminate unnecessary wires, and best of all, reduce cable clutter.
210-GQ-1000
EVGA 1000 GQ
Features
  • 5 Year Warranty and unparalleled EVGA Customer Support
  • Active Clamp +DC to DC design for efficient operation
  • EVGA ECO Intelligent Thermal Control System eliminates fan noise at low to medium loads
  • Modular Design to reduce clutter and improve airflow
  • Whisper Silent with 135mm Fluid Dynamic Bearing Fan
Specs
  • OPP (Over Power Protection)
AC Input 100 - 240 VAC, 16A, 50 - 60 Hz
MAX Output 24A 24A 83.3A 0.5A 3A
83.3A
Combined 120W 999.6W 6W 15W
Output Power 1000W @ +50C
210-GQ-0850
EVGA 850 GQ
Features
Specs
AC Input 100 - 240 VAC, 14A, 50 - 60 Hz
MAX Output 24A 24A 70.8A 0.5A 3A
849.6W
Combined 120W 849.6W 6W 15W
Output Power 850W @ +50C
210-GQ-0750
EVGA 750 GQ
Features
Specs
AC Input 100 - 240 VAC, 10A, 50 - 60 Hz
MAX Output 24A 24A 62.4A 0.5A 3A
748.8W
Combined 120W 748.8W 6W 15W
Output Power 750W @ +50C
EVGA 650 GQ
210-GQ-0650
Features
Specs
MAX Output 24A 24A 54A 0.5A 3A
648W
Combined 120W 648W 6W 15W
Output Power 650W @ +50C
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA 1000 GQ can provide up to 83.3A on the +12V rail!
Active Clamp SR+DD Circuit Layout. Full DC to DC Active Clamp circuit design improves efficiency.
Modular design allows some cables to be removed from the power supply for ease of installation and removal. You can leave off unnecessary cables to reduce case clutter and maximize case airflow.
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The EVGA GQ gives you the power you need to drive these demanding systems and achieve the best overclocks.
80 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical loads these power supplies are 90% efficiency or higher.
