Get the Most Bang for Your Buck - NVIDIA GeForce 7900 GS
NVIDIA® GeForce® 7900 GS
Hard on the competition.
Easy on your wallet.
NVIDIA® SLI™-Ready GeForce® 7900 GS graphics processing units (GPUs) deliver the most graphics performance bang for your buck, including ultra-realistic gaming experiences and resolutions up to 2560x1600. A 256-bit memory interface and fast GDDR3 memory enable exceptionally smooth frame rates at maximum quality so you don't have to choose between frame rates and image quality. The GeForce 7900 GS also delivers smooth, high-definition video playback and crisp picture quality thanks to its advanced NVIDIA® PureVideo™ technology. If you are searching for an extreme HD gaming and video experience on the PC, look no further than a GeForce 7900 GS.
Designed for extreme HD gaming
  • 90nm process delivers blazing core clocks for ultra-fast graphics performance
  • NVIDIA® SLI™-Ready Up to 2x the performance of a single GPU for unparalleled gaming experiences
  • 256-bit memory interface and fast GDDR3 memory enables rapid frame rates with all the eye-candy turned on
  • Two integrated dual-link DVI ports support high-definition flat panel displays up to 2560x1600 for an ultra-realistic HD gaming experience
As you read about HD DVD and Blu-ray movie playback on PCs, you'll come across many acronyms describing new technologies and standards. We've provided a glossary of some of the most common terms. Click here to learn more about HDCP.
Limited Lifetime Warranty - 24/7 Customer Support - 90 Days Step-Up™ Program
Built for Windows Vista™ the next-generation operating system (OS) from Microsoft®
  • Third-generation GPU architecture built for Windows Vista
  • Delivers best possible experience when running the Windows Vista 3D graphical user interface
  • NVIDIA® PureVideo™ technology delivers high-quality VMR pipeline for best-in-class video for Windows Vista
256-P2-N625-AR
SPECS AT A GLANCE
 Video Card   e-GeForce 7900GS KO 256MB EVGA Fan HDCP
 Part Number   256-P2-N625-AR
 Core Clock Speed   500MHz
 Pixel Pipelines   20
 Memory Clock Speed   1380MHz
 Memory Bandwidth   44.16GB/sec
 Bus   PCIe
256-P2-N624-AR
SPECS AT A GLANCE
 Video Card   e-GeForce 7900 GS KO
 Part Number   256-P2-N624-AR
 Pixel Pipelines   20
 Bus   PCIe
256-P2-N623-AR
SPECS AT A GLANCE
 Video Card   e-GeForce 7900GS 256MB EVGA Fan HDCP
 Part Number   256-P2-N623-AR
 Core Clock Speed   450MHz
 Pixel Pipelines   20
 Memory Clock Speed   1320MHz
 Memory Bandwidth   42.24GB/sec
 Bus   PCIe
256-P2-N622-AR
SPECS AT A GLANCE
 Part Number   256-P2-N622-AR
 Pixel Pipelines   20
 Bus   PCIe
256-P2-N620-AR
SPECS AT A GLANCE
 Part Number   256-P2-N620-AR
 Pixel Pipelines   20
 Bus   PCIe
  • Industry's only GPU architecture with full support for Microsoft® DirectX® 9.0 Shader Model 3.0 including vertex texture fetch (VTF) enables advanced shading programs for more realistic effects
  • 64-bit floating point texture filtering and blending delivers true high dynamic-range (HDR) support for cinematic lighting effects
  • Adaptive transparency antialiasing algorithm provides dramatically improved image quality with minimal performance overhead
  • Dedicated on-chip video processors dramatically increase video processing performance
    • H.264, MPEG2, and WMV9 decode acceleration provides unmatched HD and SD video playback and post processing
    • Dedicated video processor frees GPUs shaders to run 3D applications simultaneously
  • Industrys most advanced video algorithms deliver smooth video playback and crisp picture quality
    • Inverse telecine (3:2 and 2:2 pull-down correction) detects and eliminates artifacts introduced during the film to video conversion process
    • Advanced spatial-temporal de-interlacing for high definition and standard definition content provides crisp images on progressive displays
    • High-quality video scaling allows you to change window size to full screen without video noise or artifacts
  • VMR and Overlay video architecture is built for Microsoft® Windows Vista™, Windows® XP and Windows® XP Media Center Edition
Article Viewed: 65520 times since 9/6/2006
