a new gold
contender
Introducing the EVGA SuperNOVA GA Series of power supplies - the newest addition to the outstanding line of EVGA Power Supplies. Featuring 80 Plus Gold certification, 100% Japanese capacitors, a durable double-ball bearing fan, and a fully modular design, this power supply is built for long-term usage and durability. Building upon EVGA's line of 80 Plus Gold rated power supplies, the EVGA GA Series combines all these features at a great price.
![Gold Rated](https://images.evga.com/articles/01340/panel_02_element.png)
gold rated
efficiency
100%
Japanese Capacitors
Get the most reliability and greatest performance with the use of the highest possible quality Japanese Capacitors.
![Modular](https://images.evga.com/articles/01340/panel_04_element.png)
fully modular
design
Use only the cables you need, reducing cable clutter and improving case airflow.
LLC Resonant
circuit layout
GA Power Supplies feature a full DC to DC design with an LLC resonant circuit design to improve efficiency.
![psu](https://images.evga.com/articles/01340/panel_07_element.png)
EVGA eco mode
durable 135mm double ball bearing fan
EVGA ECO mode means the power supply is completely silent during low to medium loads. Couple this with a long-lasting durable double ball bearing fan and you have the perfect mix of silence and longevity with the GA Series power supplies.
made to
Protect & serve
The EVGA GA Series also includes a full suite of protections (OCP, OVP, UVP, OPP, SCP, OTP) for safety and security, and are covered by EVGA's industry-leading 10 Year Warranty and Customer Support.
![protect](https://images.evga.com/articles/01340/panel_08_element.png)
![warranty](https://images.evga.com/articles/01340/warranty.jpg)
World leading EVGA warranty and support for 10 years.
Features
Specs
- OPP (Over Power Protection)
AC Input | 100-240 VAC, 10-5A, 50/60 Hz | ||||
MAX Output | 20A | 20A | 70.8A | 0.3A | 3.0A |
849.6W | |||||
Combined | 120W | 849.6W | 3.6W | 15W | |
Output Power | 850W@50°C |
Features
Specs
AC Input | 100-240 VAC, 9-4.5A, 50/60 Hz | ||||
MAX Output | 20A | 20A | 62.5A | 0.3A | 3.0A |
750W | |||||
Combined | 120W | 750W | 3.6W | 15W | |
Output Power | 750W@50°C |
Features
Specs
AC Input | 100-240 VAC, 8-4A, 50/60 Hz | ||||
MAX Output | 20A | 20A | 54.1A | 0.3A | 3.0A |
649.2W | |||||
Combined | 120W | 649.2W | 3.6W | 15W | |
Output Power | 650W@50°C |
Features
Specs
MAX Output | 20A | 20A | 45.8A | 0.3A | 3.0A |
549.6W | |||||
Combined | 120W | 549.6W | 3.6W | 15W | |
Output Power | 550W@50°C |
