EVGA G+ Power Supplies
The G+ PSU
Since its launch in 2013, the EVGA SuperNOVA G1 power supplies have been among the longest-lasting and best-performing power supplies on the market. Despite only a few changes over the years, it's only fitting that it's time for an upgrade. Enter the G+, the new and improved fully-modular power supply line-up from EVGA with an 80+ Gold Efficiency rating.
Additionally, the G+ power supplies feature a cleaner internal layout to increase airflow, a Variable Resistor module (to increase voltage stability), two DC to DC modules for more efficient power switching on all models, a full suite of power supply protections, and EVGA's World-Leading Global 10-Year Warranty on all G+ power supplies.
1000/850 G+
(180x150x85mm)
vs.
1000 G1
(200x150x85mm)
Shorter Length
750/650 G+
(170x150x85mm)
vs.
750/650 G1
(180x150x85mm)
When it comes to building a system, even the smallest differences can make or break your build. Each G+ power supply is between 10mm to 20mm shorter than its G1 counterpart, giving you more space without sacrificing quality.
Quieter and Longer-lasting fan
G+ - 135mm Fluid
Dynamic Bearing Fan
vs.
G1 - 135mm Dual
Ball Bearing Fan
Fluid Dynamic Bearings reduce the wear and tear on a fan's bearings, reduce noise, and feature a longer-lasting life than dual ball bearing fans.
Tighter 12v Load Regulation
1000 G+
0.52%
vs.
1000 G1
3.76%
The G+ features upgrades in many areas, including a single 12V. rail, 100% Japanese capacitors, VR module, and 2 DC to DC modules on all G+ power supplies. This results in over 90% efficiency, 0.52%-0.62% 12V. load regulation, and stable power to all connected devices.
Up to 22% Quieter under load
1000 G+
24.2dB
vs.
1000 G1
30dB
Combining its Fluid Dynamic Bearing fan, along with a clean internal layout, the G+ power supply line-up reduces noise by up to 22%, compared to the G1 power supplies.
World leading warranty and support for 10 years
Specs At A Glance
Features
Gold Rated Efficiency
100% Japanese Capacitors
Fully Modular Design
A fully modular design allows cables to be removed from the power supply for ease of installation and removal. You can also leave off unncessary cables to reduce case clutter and maximize case airflow.
Tight voltage regulation (<1%)
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA G+ power supplies provide up to 83A on a single rail!
Fluid dynamic bearing fan
A high-quality 135mm fluid dynamic bearing fan gives the SuperNOVA G+ an excellent thermal and acoustic profile, and its high reliability ensures a long PSU lifetime.
To protect and to serve
This PSU will cover your circuits with complete protection: OCP, OVP, OTP, OPP, SCP, and UVP.
EVGA 1000 G+
120-GP-1000
Features
  • Whisper Silent with 135mm Fluid Dynamic Bearing Fan
Specs
  • OPP (Over Power Protection)
AC Input 100-240 VAC, 15-8A, 50 - 60 Hz
MAX Output 24A 24A 83.3A 0.5A 3.0A
999.6W
Combined 120W 999.6W 6W 15W
Output Power 1000W@50°C
EVGA 850 G+
120-GP-0850
Features
Specs
AC Input 100-240 VAC, 12-5A, 50 - 60 Hz
MAX Output 24A 24A 70.8A 0.5A 3.0A
849.6W
Combined 120W 849.6W 6W 15W
Output Power 850W@50°C
EVGA 750 G+
120-GP-0750
Features
Specs
AC Input 100-240 VAC, 10-5A, 50 - 60 Hz
MAX Output 24A 24A 62.4A 0.3A 3.0A
748.8W
Combined 120W 748.8W 3.6W 15W
Output Power 750W@50°C
EVGA 650 G+
120-GP-0650
Features
Specs
MAX Output 24A 24A 54A 0.3A 3.0A
648W
Combined 120W 648W 3.6W 15W
Output Power 650W@50°C
