Performance Refined
Introducing the EVGA Z170 motherboard lineup. These motherboards take performance to another level with next generation features like high performance native SATA 6G ports, next generation USB 3.1*, up to NVIDIA 4-Way SLI support*, Creative Core3D Audio* and more. A reimagined board and color layout with the latest EVGA GUI BIOS that focuses on functionality make the EVGA Z170 lineup a top choice for gamers, performance users and hardware enthusiasts.
* Available on EVGA Z170 Classified
Z170 Classified
Built for NVIDIA 4-Way SLI®
Creative® Core3D Audio
Available on Z170 Classified
Built in audio shielding and award winning Creative® Core3D Audio for superb sound.
Killer™ E2400 NIC
Available on Z170 Classified K
Built in Killer Ethernet helps to prioritize and reduce network latency to keep you at the top of your game.
Z170 Platform
Intel® Z170 Platform Unlocks Incredible Efficiency
Intel® Z170 Chipset
- Supports up to 8 CPU threads (4-Core + Hyper Threading)
- Supports DDR4 Memory
- First to support PCI-E 3.0 from PCH
- USB 3.1 Support (EVGA Z170 Classified)
Performance Leadership
- Up to 11% Faster CPU (SPECint_rate_base2006)
- 22% Lower TDP (65W vs 84W)
- Up to 28% Faster Intel HD Graphics (3DMark 11 Graphics Score)
UNIGINE Heaven Xtreme Overclocking
WORLD RECORD
- EVGA Z170 Classified
- EVGA GTX 980 Ti K|NGP|N
- EVGA SuperNOVA 1600 T2
- Intel® Core™ i7 6700K
EVGA Z170 Classified 4-Way Motherboard
Part Number: 151-SS-E179-KR
The EVGA Z170 Classified 4-Way is engineered from the ground up to be the best overclocking motherboard on the planet. Featuring a next generation Intel Z170 Express Chipset with DDR4 3200MHz+ memory support, this motherboard is built to perform. Two SATA Express ports, up to eight SATA 6G ports, two USB 3.1 and two M.2 ports provide robust storage and I/O options, and with support for NVIDIA SLI technology, you can pair up four NVIDIA graphics cards for insane gaming performance. Creative Core3D Audio with audio isolation provide the cleanest sound possible with full Creative suite functionality.
Specifications
- Intel® Z170 Chipset
- SLI – Up to 4 Way SLI
- 2 USB 3.1, 8 USB 3.0, 2 USB 2.0
- 4 DIMMs, dual channel DDR4, 3200 MHz+, up to 64GB
- Solid State capacitors
- Form Factor – EATX
- Dual Intel NICs, i219PHY and i210
- Creative Labs 6 channel audio + optical out
- M.2 Key M up to 32GB/s
- M.2 Key E
- Replaceable BIOS Chip
- PCI-E Disable Switches
- PCI-E Lanes – 16
Features
- 8 Phase PWM
- 8 Layer PCB
- Onboard Power, Reset, and CMOS Reset buttons
- Isolated Audio traces for better sound clarity
- Onboard POST Code Indicator/CPU Temp Monitor
- Black Nickel CPU ILM
- 300% Increased Gold Content
External I/O
- 2x USB 2.0
- 6x USB 3.0
- 2x Intel NIC (i219PHY and i210)
- HDMI 1.4
- Display Port 1.2
- Creative Core3D 5.1 Audio + Optical Out
- CMOS reset switch
Internal I/O
- 1x USB 3.0 header (2 ports)
- 1x USB 3.1 header (2 ports)
- 8 SATA 6G
- 2 SATA Express (uses 4 SATA 6G)
- M.2 Key M
- M.2 Key E
EVGA Z170 Classified K Motherboard
Part Number: 142-SS-E178-KR
The EVGA Z170 Classified K is engineered from the ground up for the hardcore gamer. Featuring a next generation Intel Z170 Express Chipset with DDR4 3600MHz+ memory support, this motherboard is built to dominate. Built in Killer Ethernet helps to prioritize and reduce network latency to keep you at the top of your game. Of course, with EVGA overclocking DNA, this board is built for overclocking with a robust VRM and hardware design that is built for speed.
Specifications
- SLI – Up to 2-Way + PhysX
- 2 USB 3.1, 6 USB 3.0, 2 USB 2.0
- 4 DIMMs, dual channel DDR4, 3600 MHz+, up to 64GB
- Form Factor – ATX
- Killer E2400 NIC
- Realtek 8 channel audio + optical out
- 2x M.2 Key M up to 32GB/s
- M.2 Key E
- PCI-E Lanes – 16
Features
- 8 Phase PWM
- 6 Layer PCB
External I/O
- 2x USB 2.0
- 6x USB 3.0
- 2x USB 3.1
- 2x NIC (Killer 2400 and i219PHY)
- HDMI 1.4
- Display Port 1.2
- CMOS reset switch
Internal I/O
- 10x SATA 6G
- 2x SATA Express (uses 4 SATA 6G)
- 2x M.2 Key M
- M.2 Key E
EVGA Z170 FTW Motherboard
Part Number: 140-SS-E177-KR
The EVGA Z170 FTW motherboard is engineered to win. Designed for next generation hardware, the EVGA Z170 FTW features a new BIOS GUI interface designed to be fast and have the best overclocking support and functionality. A highly efficient VRM provides the cleanest power to the CPU possible, fed through a CPU socket that has 1.5X the amount of gold content for improved signal quality. A total of 4 DIMM slots support up to 64GB of DDR4 memory and the PCI Express layout is optimized for improved lane distribution and better performance with native support for NVIDIA SLI technology.
Specifications
- SLI – Up to 2 Way SLI + PhysX
- 8 USB 3.0, 2 USB 2.0
- Form Factor – ATX
- Intel NIC (i219 PHY)
- PCI-E Lanes – 16
Features
- 5 Phase PWM
- 6 Layer PCB
- 150% Increased Gold Content
External I/O
- 2x USB 2.0
- 6x USB 3.0
- HDMI 1.4
- Display Port 1.2
- CMOS reset switch
Internal I/O
- 6 SATA 6G
- M.2 Key M
EVGA Z170 Stinger Motherboard
Part Number: 111-SS-E172-KR
The EVGA Z170 Stinger motherboard is engineered to exceed the best. Featuring a next generation Intel Z170 Express Chipset with DDR4 3200MHz+ memory support, this motherboard is built to perform. Four native SATA 6G ports, eight native USB 3.0 provide robust storage and I/O options, and the mITX form factor allows for an extremely compact performance system.
Specifications
- 2 DIMMs, dual channel DDR4, 3200 MHz+, up to 32GB
- Form Factor – mITX
- M.2 Key E
- PCI-E Lanes – 16
Features
- 4 Phase PWM
- 10 Layer PCB
External I/O
- 2x USB 2.0
- 6x USB 3.0
- HDMI 1.4
- Display Port 1.2
- CMOS reset switch
Internal I/O
- 4 SATA 6G
- M.2 Key E
EVGA Z170 Motherboards Comparison Chart
8 Layer PCB*
High layer count enhances stability both for heavy loads as well as high overclocking.
4-Way SLI® Support*
The EVGA Z170 Classified is rated for up to 4-Way SLI® to handle the most demanding video loads.
M.2 Support
The EVGA Z170 lineup includes support for full size storage and/or WiFi from the M.2 jacks.
High Gold Content For CPU Socket*
Higher volume of precious metal (300% Gold) used in the sockets greatly improves the conductivity and produces a cleaner signal due to less resistance / impedance.
90 Degree 24-Pin Connector*
Not having the main power for the board facing perpendicular makes it easy to get the cables routed well and out of the way.
8 Phase PWM*
An 8 Phase PWM helps to ensure that the power reaching the processor is clean and stable.
PCI-E Disable Switches*
No need to remove a card when testing, instead you can disable the slot with a dip-switch. This can greatly reduce the time spent in troubleshooting, as you do not need to disassemble anything to isolate PCI-E components.
Onboard Power, Reset and CMOS Reset Buttons
When testing on the Z170, or running it in a benching environment where you do not need to worry about wiring the board to a case to have access to power and reset buttons, they are built onto the board.
Top Notch Integrated Peripherals*
The Z170 Classified is not just focused on the upper end of extreme builds, but also with the smaller components as well. Creative Core3D audio and dual integrated Intel NICs ensure you have the best quality sound and network connection right out of the box.
