EVGA SLI
2 GPUS, can deliver as much as 2x the performance
About SLI
What is NVIDIA SLI Technology?
NVIDIA SLI technology is a revolutionary platform innovation that allows you to intelligently scale graphics performance by combining multiple NVIDIA graphics solutions in a single system with an NVIDIA nForce SLI media and communications processor (MCP).
How Does SLI Technology Work?
Using proprietary software algorithms and dedicated scalability logic in each NVIDIA graphics processing unit (GPU) and MCP, NVIDIA SLI technology delivers up to twice the performance of a single graphics solution. Bottom line, a pair of cards running in SLI mode can deliver up to twice the performance, allowing you to increase the detail or resolution in your favorite games all while running glass smooth.
Why is an SLI-Ready PC an Intelligent Investment?
An SLI-Ready PC consists of an NVIDIA nForce SLI motherboard and one SLI-Ready graphics card, thereby having the ability to be upgraded by adding a second graphics card in the future. No other PC component upgrade can offer even close to the gaming performance boost gained from adding a second graphics card.
SLI-Ready Components
NVIDIA SLI-Ready components are backed by a rigorous testing and certification process to deliver an entire certified platform solution ensuring unmatched system stability and platform compatibility.
SLI GPUs | Graphics Cards
NVIDIA SLI GPUs deliver powerful, elegant and super-rich graphics for games and other graphics-intensive applications. Combining two NVIDIA SLI-Ready certified graphics cards (with the same GPU) in a single system with an nForce SLI MCP results in up to double the graphics performance.
NVIDIA SLI-Ready GPUs feature dedicated, built-in SLI hardware logic and take advantage of the additional bandwidth of the PCI Express bus architecture. Connected by the SLI connector* (which ships with all SLI-Ready motherboards), each GPU has a maximized connection pathway, and can leverage the second card for reaching top-speed performances. SLI Technology can scale both geometry and fill rate performance for multiple GPUs and output in both digital and analog formats for the highest image quality
SLI MCPs | Motherboards
To enable NVIDIA SLI technology in your PC, you'll also need an SLI-Ready certified motherboard with an nForce SLI MCP and two physical PCI Express x16 slots.
EVGA SLI Solutions
  • 01G-P2-N793-LR
  •  : e-GeForce 8500GT 1024MB
  • 01G-P2-N795-TR
  •  : e-GeForce 8600GT 1024MB
  • 01G-P3-1280-AR
  •  : EVGA GeForce GTX 280
  • 01G-P3-1282-AR
  •  : EVGA GeForce GTX 280 SC
  • 01G-P3-1284-AR
  •  : EVGA GeForce GTX 280 SSC
  • 01G-P3-1286-AR
  •  : EVGA GeForce GTX 280 FTW
  • 01G-P3-1289-AR
  •  : EVGA GeForce GTX 280 HC - Includes Co-op Backplate
  • 01G-P3-N809-AR
  •  : e-GeForce 8800GT AKIMBO 1024MB
  • 01G-P3-N810-AR
  •  : e-GeForce 8800GT Dual Slot 1024MB
  • 01G-P3-N816-AR
  •  : e-GeForce 8800GT AKIMBO 3Phase 1024MB
  • 01G-P3-N869-AR
  •  : e-GeForce 9600 GT 1024MB
  • 01G-P3-N891-AR
  •  : e-GeForce 9800 GX2 1024MB
  • 01G-P3-N892-AR
  •  : e-GeForce 9800GX2 SC 1024MB
  • 01G-P3-N895-AR
  •  : e-GeForce 9800GX2 KO 1024MB
  • 01G-P3-N897-AR
  •  : e-GeForce 9800GX2 SSC 1024MB
  • 01G-P3-N899-AR
  •  : e-GeForce 9800 GX2 Hydro Copper 18 1024MB
  • 122-CK-NF68-A1
  •  : nForce 680i SLI 775 A1 Version
  • 122-CK-NF68-T1
  •  : nForce 680i SLI 775 T1 Version
  • 123-YW-E175-A1
  •  : nForce 750i SLI FTW
  • 128-P2-N441-LX
  •  : e-GeForce 7300GT 128MB
  • 132-CK-NF78-A1
  •  : nForce 780i SLI 775 A1 Version
  • 132-CK-NF79-A1
  •  : nForce 790i Ultra SLI 775 A1 Version
  • 132-YW-E178-A1
  •  : EVGA nForce 780i SLI FTW 775 A1
  • 256-P2-N363-TX
  •  : e-GeForce 6600 LE, 256 MB DDR
  • 256-P2-N438-LR
  •  : e-GeForce 7300GS 256MB DDR2 Passive Heatsink RoHS
  • 256-P2-N443-LX
  •  : e-GeForce 7300GT 256MB
  • 256-P2-N445-LX
  • 256-P2-N541-T2
  •  : e-GeForce 7600GS 256MB w/ Fan
  • 256-P2-N541-TX
  • 256-P2-N549-T2
  •  : e-GeForce 7600GS w/ Passive Heatsink
  • 256-P2-N742-LR
  •  : e-GeForce 8500GT 256MB HDCP
  • 256-P2-N751-AR
  •  : e-GeForce 8600GT 256MB
  • 256-P2-N751-TR
  • 256-P2-N755-AR
  •  : e-GeForce 8600GT Superclocked 256MB
  • 256-P2-N755-TR
  • 256-P2-N758-TR
  •  : e-GeForce 8600GT SSC 256MB
  • 256-P2-N761-AR
  •  : e-GeForce 8600GTS 256MB
  • 256-P2-N765-AR
  •  : e-GeForce 8600GTS Superclocked 256MB
  • 256-P2-N768-A1
  •  : e-GeForce 8600GTS SSC 256MB
  • 256-P2-N768-AR
  • 384-P3-N851-AR
  •  : e-GeForce 8800GS 384MB
  • 384-P3-N853-AR
  •  : e-GeForce 8800GS Superclocked 384MB
  • 384-P3-N965-TR
  •  : e-GeForce 9600GSO 384MB
  • 384-P3-N966-TR
  • 512-P2-N447-LR
  •  : e-GeForce 7300GT 512MB
  • 512-P2-N548-TX
  •  : e-GeForce 7600GS 512MB w/fan
  • 512-P2-N747-LR
  •  : e-GeForce 8500GT 512MB
  • 512-P2-N756-TR
  •  : e-GeForce 8600GT DDR2 512MB
  • 512-P2-N757-TR
  •  : e-GeForce 8600GT 512MB
  • 512-P2-N773-AR
  •  : e-GeForce 8600GTS 512MB
  • 512-P2-N775-AR
  •  : e-GeForce 8600GTS Superclocked 512MB
  • 512-P3-N800-AR
  •  : e-GeForce 8800GT Dual Slot 512MB
  • 512-P3-N801-AR
  •  : e-GeForce 8800GT 512MB
  • 512-P3-N802-AR
  •  : e-GeForce 8800GT Superclocked 512MB
  • 512-P3-N805-AR
  •  : e-GeForce 8800GT KO 512MB
  • 512-P3-N806-AR
  •  : e-GeForce 8800GT SSC 512MB
  • 512-P3-N807-AR
  •  : e-GeForce 8800GT AKIMBO 512MB
  • 512-P3-N808-AR
  •  : e-GeForce 8800GT AKIMBO SC 512MB
  • 512-P3-N841-AR
  •  : e-GeForce 8800GTS 512MB
  • 512-P3-N845-AR
  •  : e-GeForce 8800GTS KO 512MB
  • 512-P3-N861-AR
  •  : e-GeForce 9600 GT 512MB
  • 512-P3-N862-AR
  •  : e-GeForce 9600 GT Superclocked 512MB
  • 512-P3-N865-AR
  •  : e-GeForce 9600 GT KO 512MB
  • 512-P3-N868-AR
  •  : e-GeForce 9600 GT SSC 512MB
  • 512-P3-N871-AR
  •  : e-GeForce 9800GTX 512MB
  • 512-P3-N872-AR
  •  : e-GeForce 9800GTX SC 512MB
  • 512-P3-N873-AR
  •  : e-GeForce 9800GTX+ 512MB
  • 512-P3-N875-AR
  •  : e-GeForce 9800GTX KO 512MB
  • 512-P3-N877-AR
  •  : e-GeForce 9800GTX SSC 512MB
  • 768-P2-N831-AR
  •  : e-GeForce 8800 GTX 768MB
  • 768-P2-N835-AR
  •  : e-GeForce 8800GTX 768MB Superclocked
  • 768-P2-N837-AR
  •  : e-GeForce 8800GTX 768MB KO ACS3
  • 768-P2-N881-AR
  •  : e-GeForce 8800Ultra 768MB
  • 768-P2-N882-AR
  •  : e-GeForce 8800Ultra Special Edition 768MB
  • 768-P2-N887-AR
  •  : e-GeForce 8800Ultra Superclocked 768MB
  • 768-P3-N968-TR
  •  : e-GeForce 9600GSO 768MB
  • 896-P3-1260-AR
  •  : EVGA GeForce GTX 260
  • 896-P3-1262-AR
  •  : EVGA GeForce GTX 260 Superclocked
  • 896-P3-1264-AR
  •  : EVGA GeForce GTX 260 SSC Edition
  • 896-P3-1266-AR
  •  : EVGA GeForce GTX 260 FTW Edition
    Article Viewed: 84688 times since 6/19/2007
     Copyright © 2008 EVGA® Corporation
      Legal Info | Privacy Policy | e-Store Terms | All rights reserved
