EVGA GeForce GTX 960 SuperSC ACX 2.0+
Fine-Tuned to Perfection
Part Number: 02G-P4-2966-KR
The EVGA GeForce GTX 960 delivers incredible performance, power efficiency, and gaming technologies that only NVIDIA Maxwell technology can offer. This is the perfect upgrade, offering 60% faster performance and twice the power efficiency of previous-generation cards*. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC technology, and Dynamic Super Resolution for 4K-quality gaming on 1080P displays.
The new EVGA ACX 2.0+ cooler brings new features to the award winning EVGA ACX 2.0 cooling technology. A Memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 11°C, and optimized Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5°C. ACX 2.0+ coolers also feature optimized Swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
*Compared to GTX 660
Reviews
Why Double Ball Bearings?
EVGA ACX 2.0+ fans use double ball bearings, which offer 400% longer lifespan than the sleeve bearing fans used by competitors. The oil that is used in Sleeve bearing fans makes them vulnerable and prone to failure after time when the oil dries up. Upgrade to EVGA ACX 2.0+ and your card will go the distance!
EVGA GeForce GTX 960 Fan Chart
Run Longer, Play Longer with EVGA ACX 2.0+
EVGA ACX 2.0+ Means Better Overclocking
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum "power target" takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX 2.0+ coolers use over 4X lower power than competitor's allowing for better and more stable overclocks. In some cases, just a few watts of additional power for the card can provide an additional headroom of up to +25MHz higher GPU or +350MHz memory frequency!
Lower Fan Power = More Power for Overclocking
ACX 2.0+ Video Overview
02G-P4-2968
EVGA GeForce GTX 960 FTW ACX 2.0+
  • 1024 CUDA Cores
  • Base Clock: 1304 MHz
  • Boost Clock: 1367 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
  • Memory Bit Width: 128 Bit
  • Memory Clock: 7010 MHz
  • Memory Speed: 0.28 ns
  • Memory Bandwidth: 112.16 GB/s
Key Features
  • EVGA Backplate
  • NVIDIA MFAA Technology
  • NVIDIA GameWorks Technology
  • NVIDIA G-SYNC Ready
  • NVIDIA GPU Boost 2.0
  • NVIDIA Surround Technology
  • NVIDIA SLI Ready
  • OpenGL 4.4 Support
  • OpenCL Support
  • PCI Express 3.0 x16
  • EVGA ACX 2.0 Cooling
  • Quick Switch Dual BIOS
  • dB Inverter
  • Memory MOSFET Cooling Plate
  • Optimized Power Target
  • Straight Heat Pipes
02G-P4-2966
  • 1024 CUDA Cores
  • Base Clock: 1279 MHz
  • Boost Clock: 1342 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • NVIDIA SLI Ready
  • OpenCL Support
  • dB Inverter
02G-P4-2963
EVGA GeForce GTX 960 ACX 2.0+
  • 1024 CUDA Cores
  • Base Clock: 1127 MHz
  • Boost Clock: 1178 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • NVIDIA SLI Ready
  • OpenCL Support
  • dB Inverter
02G-P4-2962
EVGA GeForce GTX 960 Superclocked
  • 1024 CUDA Cores
  • Base Clock: 1216 MHz
  • Boost Clock: 1279 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • NVIDIA SLI Ready
  • OpenCL Support
Key Features
  • Temperature Target Control
  • Pixel Clock Overclocking
  • Robust monitoring allowing ingame, system tray and/or Logitech LCD monitoring
  • In game screenshot hotkey, supports BMP, PNG and JPG formats
Launch Precision Site
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 960 vitals. Learn more and download it here.
Key Features
  • Built-in stress tester to find and report artifacts
  • Benchmark function to quickly test your performance
  • CPU Burn In Module
  • Built-in log functionality
Launch OC Scanner Site
