Introducing the EVGA BR Series of power supplies. Building upon our already great line of Bronze rated power supplies, we sought to make the improvements our customers asked for. Our BR Series are 80 PLUS Bronze certified, with 85% efficiency or higher under typical loads. Features a non-modular design with all black full sleeved cables for that high end aesthetic, 120mm sleeve bearing quiet fan, increased 3.3V/5V voltage stability, all backed by EVGA's World Leading Warranty and Support for 3 Years.
Standard ATX Form Factor
Will fit most mATX, EATX, HPTX, and XLATX cases.
All Black Sleeved Cable
Get that high end look while staying within your budget.
Features
Hard Lined Design
Hard lined design allows your cables to be attached to the power supply for ease of installation and removal. You can be ready to go right out of the box.
Long Sleeve Bearing Fan
A 120mm Long Life Sleeve Bearing fan results in quieter operation and a longer lifespan
Bronze Rated Efficiency
80 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical load this power supply is 85% efficient or higher.
DC to DC converter
Voltage step-down for rock-solid power stability and minimal signal noise. (For 3.3V and 5V)
Power Charts
Noise Charts
Hardware Protection
While being silent, this entire series has a large single 12V rail, providing plenty of power to fuel all of your hardware. And lastly, because power without safety is pointless, a full suite of top tier circuit protections to keep you running strong and your hardware safe.
  • OPP (Over Power Protection)
World Leading
World leading warranty and support for 3 Years.
Available for 450, 500, 600, 700 BR Models
EVGA 700 BR
100-BR-0700
Features
  • 80 PLUS Bronze certified, with 85% efficiency or higher under typical loads
  • Single 12V. Rail
  • 3 Year Warranty
  • DC-DC Converter improves 3.3V/5V stability
  • Quiet and Intelligent Auto Fan for near-silent operation
Specs
AC Input 100 - 240 VAC, 10/5A, 50 - 60 Hz
MAX Output 24A 20A 58.3 0.3A 3A
699.6W
Combined 150W 699.6W 3.6W 15W
Output Power 700W @ +30C
EVGA 600 BR
100-BR-0600
Features
  • Single 12V. Rail
  • 3 Year Warranty
Specs
MAX Output 24A 20A 50A 0.3A 3A
600W
Combined 130W 600W 3.6W 15W
Output Power 600W @ +30C
EVGA 500 BR
100-BR-0500
Features
  • Single 12V. Rail
  • 3 Year Warranty
Specs
AC Input 100 - 240 VAC, 8/4A, 50 - 60 Hz
MAX Output 20A 20A 41.7A 0.3A 3A
500W
Combined 120W 500W 3.6W 15W
Output Power 500W @ +30C
EVGA 450 BR
100-BR-0450
Features
  • Single 12V. Rail
  • 3 Year Warranty
Specs
MAX Output 20A 20A 37.5A 0.3A 3A
450W
Combined 120W 450W 3.6W 15W
Output Power 450W @ +30C
