EVGA EVGA GeForce GTX 1080 Ti K|NGP|N
EVGA HydroCopper for GTX 1080 Ti K|NGP|N Edition
Designed to be
The best Overclocking
GeForce® GTX™ 1080 Ti
The GeForce® GTX™ 1080 Ti was designed to be the most powerful desktop GPU ever created, and indeed it was. EVGA built upon its legacy of innovative cooling solutions and powerful overclocking with its GTX 1080 Ti SC2 and FTW3 graphics cards. Despite the overclocking headroom provided by the frigid cooling of EVGA's patented iCX Technology, the potential of the GTX 1080 Ti still leaves room for one more card at the top...and man is it good to be the K|NG.
Single Graphics Card World Records
3DMark Time Spy
World Record: 14,219
UNIGINE Superposition
World Record: 8,642
3DMark Fire Strike Extreme
World Record: 19,361
3DMark Fire Strike
World Record: 31,770
Featuring iCX Technology, a new efficient heatpipe layout, and edge-plated PCB for improved cooling, the GTX 1080 Ti K|NGP|N is ready to go from the moment you power on and also features:
  • Guaranteed 2025 MHz+ Overclock*
  • Highly-Efficient Digital VRM
  • Dual-slot profile
  • Single-slot capable with Hydro Copper Waterblock**
*Test baseline: UNIGINE Heaven Benchmark v4.0 at room (ambient) temperature using Extreme Preset, 65C GPU card temperature
** Sold Separately
The 1080 Ti K|NGP|N is designed for power, cable management, and control, featuring right-angle PCI-e connectors and an EVBOT connector.
EVGA's K|NGP|N products are known for their distinctive appearances, and the GTX 1080 Ti K|NGP|N is no exception featuring its unmistakable mark of quality and performance.
No card is worthy enough to take the throne without EVGA's iCX Technology, and the GTX 1080 Ti K|NGP|N reigns supreme. Featuring a total of 11 global patents (pending and granted), iCX from EVGA is efficiency perfected. With 9 additional sensors embedded on the PCB, a newly designed die-cast baseplate and backplate, purposefully-directed airflow chambers, and full control using EVGA Precision XOC, EVGA's iCX is the very definition of Interactive Cooling.
9 Thermal Sensors
9 Thermal Sensors
Async Fan Control
Fan Control
Full Control With
EVGA Precision XOC
Full Control
Interactive Cooling
Interactive Cooling
Peace Of Mind Gaming
Peace Of Mind
Sync With Other Devices
Other Devices
11G-P4-6798
  • CUDA Cores: 3584
  • Base Clock: 1582 MHz
  • Boost Clock: 1695 MHz
  • Bus: PCIe 3.0
  • 2-way SLI Ready
  • Memory Detail: 11264 MB GDDR5X
  • Memory Bit Width: 352 Bit
  • Memory Clock: 11016 MHz
  • Memory Speed: 0.2 ns
  • Memory Bandwidth: 484 GB/s
Key Features
  • 9 additional temp sensors to monitor Memory and VRM
  • Asynchronous Fans
  • EVGA iCX Technology
  • GPU / Memory / PWM Thermal Status Indicator LEDs
  • Microsoft DirectX 12 API
  • New vented heatsink fin design and pin fins for optimized airflow
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • NVIDIA GPU Boost 3.0
  • OpenGL 4.6 Support
  • Redesigned cooling with L-shaped contact fins to improve contact surface area for better heat dissipation
  • Safety fuse to protect components from damage due to improper installation or other component failures
  • VR Ready
  • Vulkan API
11G-P4-6799
EVGA GeForce GTX 1080 Ti K|NGP|N HydroCopper
  • CUDA Cores: 3584
  • Bus: PCIe 3.0
  • 2-way SLI Ready
Key Features
  • 11 additional temp sensors to monitor Memory and VRM
  • EVGA Hydro Copper Waterblock
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • VR Ready
  • Vulkan API
