EVGA_JacobF
- Ribbons : 26
shawnoen
Re:EVGA Power Boost!
2010/12/21 10:10:57
cisco760ca
2010/12/21 10:18:30
z3r0t0l0rence
- Ribbons : 20
2010/12/21 10:20:23
Thanks for posting this. I know that many members were asking when EVGA was going to provide this info.
i7 930 OC 4.21 EVGA E758 GSkill 12GB Evga GTX 780 SC 2x Kingston 240 Raid 0 2x Seagate 4TB
iammrfrank
2010/12/21 10:25:21
Awesome. I have a board that meets specs, but it won't let me opt in.. awesome...
EVGA_JacobF
- Ribbons : 26
2010/12/21 10:31:09
iammrfrank Awesome. I have a board that meets specs, but it won't let me opt in.. awesome... Try now.
tsymyn
2010/12/21 10:31:27
So, does this only work on Classified boards? Would it be unsafe on a competitor's board?
iammrfrank
2010/12/21 10:32:28
EVGA_JacobF
- Ribbons : 26
2010/12/21 10:35:18
tsymyn So, does this only work on Classified boards? Would it be unsafe on a competitor's board? Works on all boards, but "officially" tested on EVGA boards.
weaser31
2010/12/21 10:37:24
got one thanks evga still not sure what this does though
Moltenlava
- Ribbons : 28
2010/12/21 10:38:09
How do you know if your one of the lucky 75? Will it stop allowing people to request one once it hits he 75 limit or will you look back at when people requested it and sort it out that way? (the reason I ask that is because the date I requested it came up) . Power Boost was the wrong name to use since it doesnt actually increase the power just stabilizes it and stops the 24-pin connector from getting overloaded. Also the name gives the impression it will somehow help your performance (some people will associate power with performance). You should have called it Power Pal. Good job EVGA at getting this thing out, I still dont agree with only 75 units for free considering you must have thousands of qualifying boards but hopefully I am one of the lucky 75.
post edited by Moltenlava - 2010/12/21 10:43:35
EVGA_JacobF
- Ribbons : 26
2010/12/21 10:46:11
Once it hits 75 it will stop allowing signups.
EVGA_JacobF
- Ribbons : 26
2010/12/21 10:46:39
Moltenlava How do you know if your one of the lucky 75? Will it stop allowing people to request one once it hits he 75 limit or will you look back at when people requested it and sort it out that way? (the reason I ask that is because the date I requested it came up) . Power Boost was the wrong name to use since it doesnt actually increase the power just stabilizes it and stops the 24-pin connector from getting overloaded. Also the name gives the impression it will somehow help your performance (some people will associate power with performance). You should have called it Power Pal. Good job EVGA at getting this thing out, I still dont agree with only 75 units for free considering you must have thousands of qualifying boards but hopefully I am one of the lucky 75. It can actually help boost the +12v rail and keep it stable.
Shockjockey
- Ribbons : 18
2010/12/21 10:53:13
Thanks for posting this.I signed up for my free one.
Asus Sabertooth x99 5930k (4.5ghz) 16gb Corsair DDR4 (3000) EVGA 1000w psu Zotac 980ti x 2 Samsung 850 pro 500 SSD HPLP3065 30in Monitor 2560x1600
Moltenlava
- Ribbons : 28
2010/12/21 11:01:17
EVGA_JacobF Moltenlava How do you know if your one of the lucky 75? Will it stop allowing people to request one once it hits he 75 limit or will you look back at when people requested it and sort it out that way? (the reason I ask that is because the date I requested it came up) . Power Boost was the wrong name to use since it doesnt actually increase the power just stabilizes it and stops the 24-pin connector from getting overloaded. Also the name gives the impression it will somehow help your performance (some people will associate power with performance). You should have called it Power Pal. Good job EVGA at getting this thing out, I still dont agree with only 75 units for free considering you must have thousands of qualifying boards but hopefully I am one of the lucky 75. It can actually help boost the +12v rail and keep it stable. You know better than me but it still a bit of an ambiguous name, I am sure some people will get the wrong impression about what its for but I guess it may allow them to OC more and thus giving them the boost. It will be interesting to find out if my higher GPU clocks will finally heed higher Vantage scores since I used to be confused why I got a lower score with a higher clock, it may have been heat related but temps were within limits, we shall see I guess. Hopefully i can stick my physX card back in without taking a performance hit either.
post edited by Moltenlava - 2010/12/21 11:11:31
doctahg
2010/12/21 11:15:42
Missed by 5 minutes..sheesh!
Intel 3930k Evga Dark X79 G.SKILL Trident X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB and other assorted SSD's and Hd's Enermax 1000 Revolution87Gold EVGA 06G-P4-2793-KR GeForce GTX TITAN SuperClocked Signature 6GB Thermaltake Level10 GT Snow Edition Thermaltake Water Extreme 2
2010/12/21 11:19:52
doctahg Missed by 5 minutes..sheesh! I know & $20 is kind of high, IMO! Jacob, can you put more than one on your mobo for added power?
post edited by seabigbear - 2010/12/21 11:30:45
Moltenlava
- Ribbons : 28
2010/12/21 11:22:31
seabigbear doctahg Missed by 5 minutes..sheesh! I know & $20 is kind of high, IMO! Yeah, hopefully most people who want one can offset the price with EVGA bucks, atleast then some more can get it for "free" or atleast at a reduced price. I guess we do need to remember that EVGA does alot of good, even the best can make a boob or two now and then.
Dissi
2010/12/21 11:40:46
I was 2 slow
EVGA_JacobF
- Ribbons : 26
2010/12/21 11:51:50
More than 1 doesn't really help you much, 1 is all you need.
TheGshow
2010/12/21 11:54:26
DAMN, just missed it :( and $20 is out of my price range.....
Intel Core i7-5930K @ 4.25Hz, 4251 MHz EVGA X99 Classified 32GB of G.Skill DDR4-3000 (4gb x 8) EVGA RTX 2080ti Black Edition EVGA GeForce GT 740 4GB Superclocked(Dedicated Physics)EVGA NU AUDIO OCZ ZX Series 1250W Fully-Modular 80PLUS Gold Samsung 970 EVO 1tb nvme M.2 WDC 2tb Corsair Hydro H105 Extreme 240mm CPU cooler Corsair Obsidian 750D Full Towed Case
rbh5081
2010/12/21 11:56:51
Only 75? What the rest of us who have to worry about are boards catching fire? I thought this was the fix they where going to send us?
Stop being zombie's let's make a real change this year LIVE FREE my friends.
SAMCRO-FTW
2010/12/21 11:58:15
Really? You spent over 1k in graphics cards, at lest 300ish for a board, and 20$ is just a step too far?
diegorubeus
- Ribbons : 8
2010/12/21 12:05:13
i hope this little "boost" is gonna start being shipped with the new evga bards. is it needed on the new boards???
-INTEL CORE i7 930 D0 @ 4.00 GHZ LINX STABLE -WD CAVIAR BLUE 320GB (MEDIA) -EVGA X58 SLI LE MOTHERBOARD (E757) -LG GH22NS40 DVD MULTI BURNER -CORSAIR H50 WC KIT IN PUSH-PULL CONFIG -ACER S231HLbid 23" LED 1080P -EVGA GTX 580 SUPERCLOCKED W/BACKPLATE -CORSAIR HX1050 PRO SERIES PSU -CORSAIR VENGEANCE 12GB DDR3 1600MHZ -THERMALTAKE ELEMENT S CASE -CRUCIAL M4 128GB SSD (OS,GAMES)
ajs-cfg
2010/12/21 12:25:16
I would like to get one of these for my gaming rig (SLI LE board and 2X GTX470's). The "buy now" option is gone so I assume they are out of stock. I am sure you guys have heard this question about a million times today, but do you by chance know when they will be back in stock? IMO, $20 is more than worth it especially when you have over 1k invested in parts already...hopefully I will be able to jump on this when they come back in stock. I haven't really followed the threads regarding the burning power connectors, but I would assume since my mobo is listed as a compatible product, it would be wise to have one installed.
Main Rig: EVGA X58 SLI LE Mobo (i7 930) 6GB Corsair Dominator (TR3X6G1600C8D) 160GB Intel X-25M G2 SSD 1TB WD Caviar Black HDD EVGA GTX 580 3GB (with another on the way!) Corsair HX850 PSU Coolermaster HAF X Case (Work Rig Identical, but w/ EVGA GTS250 GFX card, 80GB X-25M G2 and HAF922 case)
iceman0124
2010/12/21 12:29:40
It "looks" kinda neat, but I'd like to see some examples of real world benefits, other than just loose claims....will this fix a few minor issues for some and have no impact at all for most users?, will everyone see a marked improvement etc...For those with high end PSU's will it matter at all...any possible negative effects (aside from improper install) ? etc...
Corsair Obsidian D ~Silverstone ST-1000-P~ i7 950 @ 4.08GHZ/1.232V~GA X58A-UD3R~ 2X EVGA GTX 660 Ti's in SLI~12GB Crucial Ballistix DDR3 1600 ~120GB OCZ Agility 2 SSD/ 1TB WD 7200 RPM 64MB cache ~Samsung Blue Ray / DVDRW~ GTX 460 for physX ~ XFI-TI PCIE~ Asus 1080P 120HZ LCD/NVIDIA 3D vision kit ~ Win 7 Pro-64
whodaddy
2010/12/21 12:33:31
I woulld like to get one as well Just noticed this thread??
E-759 CLASSIFIED & I7 920 DO B261 OCZ DDR 3 1600 Gold 6GS / TFC 480 and TFC 360 w KOOLANCE RAD SUPPORT 2x655 PUMPS IN SERIES/ BITS 150Z RES EK FULL COVERAGE BLOCK / BITS COMPRESSION/ROTARY FITTINGS EK HF SUPREME PLEXI COPPER CPU BLOCK 1/2X5/8 TUBING 2x GTX 470 SC W EK BLOCKS/WD 150 RADPTOR WD 300 RAPTOR WD 1TB CORSAIR 800D CASE/CORSAIR HX-1000 http://www.heatware.com/eval.php?id=67849
mmuthiah
2010/12/21 12:35:35
Is this another Black "Tuesday"?? I dont accept this kind of lottery thing...I'm registered my board E759 on their site...and i was waiting to get an email from them...suddenly this lottery thing that i have missed.. I dont want to pay for this.....How long i need to wait for this....very frustrating.. Did they just sold 75 boards (atleast from EVGA.com directly)?
post edited by mmuthiah - 2010/12/21 12:46:46
divvichild
2010/12/21 12:38:27
Any plans to re-open the promotion an additional time? 75 is quite limited considering the massive amount of EVGA customers...........
KMcCrackan
2010/12/21 12:57:32
This sucks that their already gone. Just got home from work hoping to finally have some good news about my 2 boards and nothing. Wouldn't the fair thing to have had some type of lottery? Not everyone sits in front of their computers all day:(
