EVGA 9800GX2 Hydro Copper 18 waterblockEVGA is proud to announce the first ever EVGA designed Water Block; the EVGA 9800GX2 Hydro Copper 18 waterblock, with an exclusive internal design to maximize heat transfer along with a 100% copper design, the EVGA 9800GX2 Hydro Copper 18 waterblock is the best way to significantly lower the operating temps of the worlds fastest graphics solution. High flow designed internals and barbs give you the minimum in flow restriction, allowing for the lowest temps, and the highest overclock possible. The EVGA 9800GX2 Hydro Copper 18 waterblock is the Ultimate Solution for the Uber-Enthusiast. Now available for order! There is a limited QTY available so don't miss out on your opportunity to have the EVGA 9800GX2 Hydro Copper 18 waterblock. |
Included:
| Article Viewed: 102120 times since 4/30/2008 | ||||||||||||||
pattern design maximizes surface area and reduces temps.
