EVGA inDtube
EVGA introduces inDtube:
WINNERS ANNOUNCED. CLICK HERE TO VIEW WINNERS!
A compact USB 2.0 Hybrid TV Tuner capable of decoding both NTSC and the newer ATSC signals as well as over-the-air Hi-Definition Television up to 1080i. Designed to be easily taken with you on vacation, business trips, or for use in your own backyard with a notebook computer, inDtube is the solution for a complete "TV anywhere" package. Not only a TV Tuner, inDtube will also capture video and audio from external sources. This feature allows you to save your older media in to a digital format which can easily be shared amongst your friends and family.
Features:
  • ATSC NTSC Signals
  • Hi-Definition (over-the-air)
  • Electronic Program Guides
  • DVR Functions
  • Windows XP, MCE, Vista 32 support
  • S-Video, Composite Video, Stereo Audio (AV-Input Cable)
Accessories:
  • Portable, Magnetic, Telescopic Antenna
  • Remote Control
  • USB Extension Cable
  • AV-Input Adapter
  • F-Connector to MCX Adapter
  • Printed Manual
  • Driver and Applications Disc
100-U2-IDTV-A1
inDtube
Part Number 100-U2-IDTV-A1
Bus USB 2.0
Interface S-Video, RCA, Coax
Audio Stereo Input 3.5mm
Signals NTSC, ATSC
Article Viewed: 145818 times since 4/25/2008 8:21:02 PM
