Ultimate Gaming with
EVGA Precision XOC + OC Scanner X
Take on today's most challenging, graphics-intensive games without missing a beat. The EVGA GeForce GTX 1070 Ti delivers the incredible speed and power of NVIDIA Pascal - the most advanced gaming GPU architecture ever created. This is the ultimate gaming platform.
Take your EVGA GeForce GTX 1070 Ti to the next level with exclusive EVGA Precision XOC / EVGA OC Scanner X integration. With the click of one button, EVGA Precision XOC will detect, scan, and apply your optimal overclock!
GTX 1070 Ti Comparison Chart
| EVGA GRAPHICS CARD | PART NO. | MAX POWER | LED | BIOS | COOLER | POWER TYPE | BACKPLATE |
| EVGA GeForce GTX 1070 Ti FTW Ultra Silent | 08G-P4-6678-KR | 235W | Yes (WHITE) | 2 | ACX 3.0 | 10+2 | Yes |
| EVGA GeForce GTX 1070 Ti FTW2 | 08G-P4-6775-KR | 235W | RGB | 2 | iCX | 10+2 | Yes |
| EVGA GeForce GTX 1070 Ti SC HYBRID | 08G-P4-5678-KR | 217W | Yes (WHITE) | 1 | Hybrid | 5+1 | Yes |
| EVGA GeForce GTX 1070 Ti SC Black Edition | 08G-P4-5671-KR | 217W | Yes (WHITE) | 1 | ACX 3.0 | 5+1 | No |
| EVGA GeForce GTX 1070 Ti | 08G-P4-5670-KR | 217W | Yes (WHITE) | 1 | Blower | 5+1 | No |
Available with EVGA iCX Cooling
(Part Number 08G-P4-6775-KR)
Optimized airflow fin design
An optimized air flow design directs air through the fin holes, while half open fins maximize airflow to important components and L-shaped fins increase surface contact.
Interlaced pin fin on Baseplate
Diecast form fitted baseplate and backplate
Backplate makes direct contact with all vital components and new baseplate design with integrated heatpipe significantly reduces component temperatures
Play longer! Overclock Better!
Interaction with Other Devices*
08G-P4-6678-KR
- CUDA Cores: 2432
- Base Clock: 1607+ MHz
- Boost Clock: 1683+ MHz
- SLI Support: 2-way
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
- Bandwidth: 256.3 GB/s
Key Features
- EVGA ACX 3.0 Cooling
- Microsoft DirectX 12 API
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- NVIDIA GPU Boost 3.0
- OpenGL 4.6 Support
- PCI Express 3.0
- VR Ready
- Vulkan API
08G-P4-6775-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- 10+2 Phase Power Design
- Adjustable RGB LED
- Asynchronous Fans
- EVGA Double BIOS
- EVGA iCX Technology
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
08G-P4-5678-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- Built in White LEDs
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
08G-P4-5671-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
08G-P4-5670-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
