PWM (Pulse Width Modulation) Frequency allows you to select the frequency range for either higher overclocks or lower power consumption. This feature allows you to have much better manage of your systems performance as well as its power consumption. Just another way the EVGA X58 SLI Motherboard puts you in control.
