EVGA UV Plus+
EVGA UV Plus+
UV Plus+
A USB VGA Display Adapter. Allows for multiple displays in minutes.
EVGA introduces the new UV Plus+ Family: Consisting of both the UV12 and the UV16, take any available USB port on your Desktop or Notebook and turn it into an additional video output for use with another display. With a small footprint and a unique magnetic-stackable design for use with multiple UV12 or UV16 units, UV Plus+ allows for additional displays to increase productivity by expanding, rotating, or mirroring your virtual workspace through an easy to understand and operate software interface. UV Plus+ is powered by USB and uses Lossless Compression for transferring video signal which provides a crystal clear viewing experience on your additional display. The GPU-less design utilizes a virtual driver and high-performance DDR memory with full support for Windows Vista Aero and high resolution capabilities. With all of these features in one tiny package, the EVGA UV Plus+ is the perfect, easy solution for an additional monitor in only minutes.
Features:
  • DVI and VGA Support
  • 1280x1024 or 1440x900 (UV12)
  • 1600x1200 or 1680x1050 (UV16)
  • USB 2.0 Powered
  • Windows Vista Aero Support
  • Windows XP and Vista 32bit Support
  • No onboard GPU
  • High-Performance DDR Memory
  • Uses a virtual driver
  • Stackable by design with a small footprint
  • Completely silent operation
  • Onboard power and status indicator LEDs
  • Portable, making it easy for travel
Accessories:
  • Carrying Case
  • USB Cable
  • DVI to VGA Adapter
  • Printed Manual
  • Driver CD
Display Modes:
  • Can easily Mirror the main display
  • Extend left, right, above, or below
  • Can be rotated left, right, or upside-down
100-U2-UV16-A1
*UV16 Shown
UV Plus+ - UV16 / UV12
Part Number 100-U2-UV16-A1  100-U2-UV12-A1
Bus USB 2.0
Interface DVI-I
Resolution Refresh rates available at 32 bit colour quality UV12 UV16
640x480 60 72 75 85
720x400 70 85
800x600 56 60 72 75 85
832x624 75
800x480 60
848x480 60
1024x768 60 70 75 85
1152x864 75
1152x870 75
1280x720 60
1280x768 60 75 85
1280x800 60
1280x960 60 85
1280x1024 60 75
1360x768 60
1366x768 60
1368x768 60
1400x1050 60 75 85
1440x900 60
1600x1200 60
1680x1050 60
Article Viewed: 26805 times since 4/30/2008 5:04:18 PM
 Copyright © 2008 EVGA® Corporation
  Legal Info | Privacy Policy | e-Store Terms | All rights reserved
