Select Region:
EVGA Hydro Copper 18 9800GX2 Block
EVGA 9800GX2 Hydro Copper 18 waterblock
EVGA is proud to announce the first ever EVGA designed Water Block; the EVGA 9800GX2 Hydro Copper 18 waterblock, with an exclusive internal design to maximize heat transfer along with a 100% copper design, the EVGA 9800GX2 Hydro Copper 18 waterblock is the best way to significantly lower the operating temps of the worlds fastest graphics solution. High flow designed internals and barbs give you the minimum in flow restriction, allowing for the lowest temps, and the highest overclock possible. The EVGA 9800GX2 Hydro Copper 18 waterblock is the Ultimate Solution for the Uber-Enthusiast.
Now available for order! There is a limited QTY available so don't miss out on your opportunity to have the EVGA 9800GX2 Hydro Copper 18 waterblock.
  • EVGA Exclusive pattern design maximizes surface area and reduces temps.
  • 100% Copper design
  • Compatible with all 9800GX2 cards
  • 100% testing on every block
  • Cool's GPU, VREG, I/O Chip and Memory
  • Includes high quality 1/2'' or 3/8'' High Flow fittings
  • SLI Compatible
  • Flexible barb design allows 4 different fitting configurations, giving maximum flexibility for water cooling placement accessories
Included:
  • EVGA Hydro Copper 18 9800GX2 Copper Water Block
  • 2x High quality 1/2'' or 3/8'' High Flow fittings
  • 2x High quality Stop Fitting
  • 2x 1/2'' Stainless Steel Hose Clamps
  • 2x 3/8'' Stainless Steel Hose Clamps
200-CU-HC18-B1
Part Number 200-CU-HC18-B1
Fittings Supports 3/8'' & 1/2'' Systems
Fitting Config. Up to 4
Material Copper
Article Viewed: 86988 times since 04/30/2008
© 2012 EVGA® Corporation | Legal Info | Privacy Policy | Store Terms | All Rights Reserved
