GX2 Approved Power Supply List
9800GX2 Powersupply Notice 9800GX2 Powersupply MUST READ.
Important 9800GX2 Powersupply Notice
The following is a list of powers supplies which have been tested to work on GeForce 9800GX2. These powersupplies meet the requirements for power ratings, and have at least one 6-pin and one 8-pin PCI Express power connectors. Please also note, that it is not recommended to use a 6pin to 8pin converter cable. The NVIDIA 9800GX2 requires one 8 pin connector, and one 6 pin connector.
NOTE: A number of system power supplies in the market use a modular power connector to provide 6-pin and 8-pin outputs from the same cable. A subset of these modular connectors have a mechanical latch that is too wide and do not fit the 8-pin PCI-E power connector on the GeForce 9800 GX2 graphics card and are marked with an asterisk (*) in the table. These power supplies will work with the GeForce 9800 GX2 GPU with a PCI Express power connector adapter. These adapters will come in the form of an 8pin to 8pin connector, and a 6pin to 6pin connector, and are now available below.
Model Rating Connectors
2theMax RF Extreme 750 750W Four 6-pin, Two 8-pin
AcBel Model PC6018 700W Two 6-pin, Two 8-pin
AcBel Model PC7030 750W Two 6-pin, Two 8-pin
Aerocool EN53112 1020W Six 8-pin/6-pin*
Amacrox AX1000-GLN 1000W Two 6-pin, Two 8-pin/6-pin*
Amacrox AX750-EP 750W Two 6-pin Two 8-pin/6-pin*
Amacrox AX850-EP 850W Two 6-pin, Two 8-pin/6-pin*
Antec Quattro TPQ-1000 1000W Two 6-pin, Two 8-pin/6-pin *
Antec Quattro TPQ-850 850W Two 6-pin, Two 8-pin/6-pin*
ATNG APE-1100FM 950W Four 6-pin, Two 8-pin
ATNG APE-1100XM 950W Four 6-pin, Two 8-pin
Channel Well CWT-1000VC 1000W Three 6-pin Three 8-pin
Channel Well CWT-1200VC 1200W Three 6-pin Three 8-pin
Channel Well CWT-750VH 750W Two 6-pin Two 8-pin
Compucase (HEC ) HEC750DR-AT 750W Two 8-pin, Two 8-pin
CoolerMaster Real Power Pro (RS-C50-EMBA-D2) 1250W Six 6-pin, Two 8-pin
CoolerMaster Real Power Pro (RS-750-ACAA-A1) 750W Two 6-pin Two 8-pin
CoolerMaster RS-A00-EFAM-A3 1000W Four 6-pin, Two 8-pin
Corsair HX1000W 1000W 1000W Six 8-pin/6-pin *
FSP Epsilon 80Plus 700 700W One 6-pin, One 8-pin/6-pin *
FSP Everest 800 800W Two 6-pin Two 8-pin/6-pin*
FSP Everest 900 900W Two 6-pin Two 8-pin/6-pin*
Gigabyte Odin (GE-MK20A-D1) 1200W Three 6-pin, Three 8-pin
Meridian XClio Diamondpower 880W Two 6-pin Two 8-pin adapter Two 6-pin
Meridian XClio Diamondpower 1080W Three 6-pin Three 8-pin adapter Two 6-pin
Meridian XClio Diamondpower 680W Two 6-pin Two 8-pin adapter Two 6-pin
PC Power and Cooling Turbo-Cool 1000W Two 6-pin, Two 8-pin/6-pin*
PC Power and Cooling Turbo-Cool 860 860W Two 6-pin, Two 8-pin/6-pin*
Silverstone Decathlon DA1200 1200W Four 6-pin or Four 8-pin or Four 6-pin, Two 8-pin
Silverstone Strider ST1000 1000W Four 6-pin or Four 8-pin or Four 6-pin, Two 8-pin
Sparkle SPI1000GCM 1000W Two 6-pin Two 8-pin/6-pin*
Sparkle SPI900GCM 900W Two 6-pin Two 8-pin/6-pin*
SPI Electronic Co., Ltd Epsilon 800 800W Two 6-pin Two 8-pin/6-pin*
Super Flower SF-1000R14HE 1000W Two 6-pin, Two 8-pin/6-pin
Super Flower SF-1100R14HE 1100W Two 6-pin, Two 8-pin/6-pin*
Super Flower SF-850R14HE 850W Two 6-pin, Two 8-pin/6-pin*
Super Talent Atomic Juice PS-700 700W One 6-pin, One 8-pin/6-pin*
TACENS Superpro 1000 1000W Four 8-pin/6-pin*
TACENS Superpro 700 700W Two 8-pin/6-pin*
Tagan BZ1300 1300W Four 6-pin, Two 8-pin/6-pin
Tagan ITZ1300 1300W Four 6-pin Two 8-pin/6-pin*
Tagan ITZ800 800W Two 6-pin Two 8-pin/6-pin*
Thermaltake Toughpower W0133 Cable Management 1200W Three 8-pin Three 6-pin
Thermaltake Toughpower W0172 850 AP-1 850W Two 6-pin, Two 8-pin
Topower EP-1200P10 1200W Six 6-pin or Four 6-pin+Two 8-pin
XIGMATEK NRP-HC1001 1000W Three 6-pin, Three 8-pin*
XIGMATEK NRP-HC1201 1200W Three 6-pin, Three 8-pin*
XIGMATEK NRP-HC1501 1500W Four 6-pin, Four 8-pin*
Zalman ZM850-HP 850W Two 6-pin Two 8-pin/6-pin *
203-EV-0020-01
8pin to 6pin connector for 9800GX2
Part Number 203-EV-0020-01
Compatible Graphics Cards 9800 GX2
203-EV-0020-01
8pin to 8pin connector for 9800GX2
Part Number 203-EV-0019-01
top
Article Viewed: 56155 times since 03/18/2008 7:06:56 AM
 Copyright © 2009 EVGA® Corporation   Legal Info  |  Privacy Policy  |  e-Store Terms  |  All rights reserved
