Select Region:
EVGA 9600 GT
Big on performance. Easy on the wallet.
The new standard for price/performance has now been set. The EVGA GeForce 9600GT offers a powerfully immersive entertainment experience designed for extreme high-definition gaming and video playback. Play the hottest DirectX 10 games with awesome performance and watch the latest HD DVD and Blu-ray movies with brilliant image clarity. Featuring next generation GeForce and PureVideo HD technologies, the EVGA GeForce 9600GT puts amazing graphics performance within your reach.
  • 65nm GPU accelerated up to 740MHz*
  • 64 Stream Processors operating at over 1.83GHz*
  • 23.7 Billion pixels per second*
  • 512MB memory at 62.4GB/s of bandwidth*
  • 2nd Generation PureVideo HD equipped
  • PCI Express 2.0 ready
Features:
  • Full DX10 support Full Direct X 10 and Shader Model 4.0 support delivers uparalleled levels of graphics realism and film-quality effects.
  • Unified Shader Architecture - Combines vertex, pixel and geometry shaders for an overall more efficient architecture.
  • NVIDIA Quantum Effects Enables a new level of physics effects to be rendered and simulated on the GPU.
  • 128-bit HDR with FSAA Realistic High Dynamic Range lighting, now with support for anti-aliasing!
  • Built for Microsoft Windows Vista Fourth generation GPU architecture gives Windows Vista users the best possible experience with Windows Aero 3D user interface.
  • PCI Express 2.0 Provides support for Next Generation PC Platforms, and also fully backwards compatible.
  • Blu-ray/HD DVD Support Featuring revolutionary second generation NVIDIA PureVideo HD Engine.
Available at:
Buy the EVGA 9600 GT here.
All these new technologies found in the e-GeForce 9 series GPU processors allow the PC Platforms to experience high-resolution, high performance gaming, and stellar high-definition visuals.
512-P3-N867-AR
e-GeForce 9600 GT SSC
Part Number 512-P3-N867-AR
Core Clock Speed 740MHz
Processing Cores 64
Memory Clock Speed 1950MHz
Memory Bandwidth 62.4GB/sec
Shader Clock Speed 1835MHz
Bus PCI-E 2.0
Interface DVI-I, DVI-I, HDTV-7
upon registration
512-P3-N865-AR
e-GeForce 9600 GT KO
Part Number 512-P3-N865-AR
Core Clock Speed 700MHz
Processing Cores 64
Memory Clock Speed 1900MHz
Memory Bandwidth 60.8GB/sec
Shader Clock Speed 1773MHz
Bus PCI-E 2.0
upon registration
512-P3-N862-AR
e-GeForce 9600 GT Superclocked
Part Number 512-P3-N862-AR
Core Clock Speed 675MHz
Processing Cores 64
Memory Clock Speed 1800MHz
Memory Bandwidth 57.6GB/sec
Shader Clock Speed 1674MHz
Bus PCI-E 2.0
upon registration
512-P3-N861-AR
e-GeForce 9600 GT
Part Number 512-P3-N861-AR
Core Clock Speed 650MHz
Processing Cores 64
Shader Clock Speed 1625MHz
Bus PCI-E 2.0
upon registration
*SSC model
Article Viewed: 176687 times since 02/21/2008 7:19:00 AM
© 2012 EVGA® Corporation | Legal Info | Privacy Policy | Store Terms | All Rights Reserved
