EVGA 8800GT AKIMBO
The Superior Solution
It's time to suit up and join the front lines with the fastest 8800GT card in its class, the EVGA 8800GT AKIMBO card: Featuring a 65nm GPU with an astonishing GPU Core clock of 720MHz, the exclusive dual slot heat sink and fan drops temperatures as much as 25 degrees Celsius, keeping your card cool and ready to perform at any given notice. Your new secret weapon supports 2-way SLI and the latest PCI-E 2.0 standard, now is the time to lock, load, and game. Frag it up with the EVGA 8800GT AKIMBO card.
Specs:
  • 65nm GPU boosted to a mind blowing 720MHz
  • 3 phase power design for extreme overclocking
  • Incredible fillrate of 40.3 Billion pixels per second
  • 2GHz Memory clock
  • Superior Cooling lowers temps as much as 25c
Features:
  • Full DX10 support Full Direct X 10 and Shader Model 4.0 support delivers uparalleled levels of graphics realism and film-quality effects.
  • Unified Shader Architecture - Combines vertex, pixel and geometry shaders for an overall more efficient architecture.
  • NVIDIA Quantum Effects Enables a new level of physics effects to be rendered and simulated on the GPU.
  • 128-bit HDR with FSAA Realistic High Dynamic Range lighting, now with support for anti-aliasing!
  • Built for Microsoft Windows Vista Fourth generation GPU architecture gives Windows Vista users the best possible experience with Windows Aero 3D user interface.
  • PCI Express 2.0 Provides support for Next Generation PC Platforms
  • Blu-ray/HD DVD Support Featuring revolutionary second generation NVIDIA PureVideo HD Engine
All these new technologies found in the e-GeForce 8 series GPU processors allow the PC Platforms to experience high-resolution, high performance gaming, and stellar high-definition visuals.
512-P3-N808-AR
e-GeForce 8800 GT AKIMBO Superclocked
Part Number 512-P3-N808-AR
Core Clock Speed 720MHz
Processing Cores 112
Memory Clock Speed 2000MHz
Memory Bandwidth 64.0GB/sec
Shader Clock Speed 1728MHz
Bus PCI-E 2.0
Interface DVI-I, DVI-I, HDTV-7
upon registration
512-P3-N807-AR
Part Number 512-P3-N807-AR
Core Clock Speed 600MHz
Memory Clock Speed 1800MHz
Memory Bandwidth 57.6GB/sec
Bus PCI-E 2.0
upon registration
202-F2-EV03-A1
EVGA AKIMBO Cooler
Part Number 202-F2-EV03-A1
Part AEVGA AKIMBO Dual Slot Cooler
Part BEVGA AKIMBO Backplate
Part CDual Slot Bracket
Works only for 8800GT Graphic Cards
Article Viewed: 81360 times since 02/15/2008 5:56:19 PM
 Copyright © 2010 EVGA® Corporation   Legal Info  |  Privacy Policy  |  e-Store Terms  |  All rights reserved
