Select Region:
e-Geforce 8800 GTS 512
The EVGA 8800 GTS
All the performance at the right price.
The ultimate in price/performance has arrived. Featuring 128 stream processors each individually clocked at a blazing fast 1.67GHz and an impressive 256-bit 512MB frame buffer interface giving you over 62GB/s of memory bandwidth, the EVGA GeForce 8800GTS 512MB delivers a level of price/performance that enthusiast gamers have been demanding.
Performance:
  • New 65nm GPU clocked at 670MHz
  • 128 Stream Processors at 1.67GHz
  • 512MB of DDR3 at 1.94GHz
  • Second Generation PureVideo HD
  • PCI Express 2.0 Ready
The EVGA 8800 GTS BUILT TO GAME!
Features:
  • Full DX10 support Full Direct X 10 and Shader Model 4.0 support delivers uparalleled levels of graphics realism and film- quality effects
  • Unified Shader Architecture - Combines vertex, pixel and geometry shaders for an overall more efficient architecture.
  • NVIDIA Quantum Effects Enables a new level of physics effects to be rendered and simulated on the GPU.
  • 128-bit HDR with FSAA Realistic High Dynamic Range lighting, now with support for anti-aliasing!
  • Built for Microsoft Windows Vista Fourth generation GPU architecture gives Windows Vista users the best possible experience with Windows Aero 3D user interface.
  • PCI Express 2.0 Provides support for Next Generation PC Platforms
  • Blu-ray/HD DVD Support Featuring revolutionary second generation NVIDIA PureVideo HD Engine
All these new technologies found in the e-GeForce 8 series GPU processors allow the PC Platforms to experience high-resolution, high performance gaming, and stellar high-definition visuals.
512-P3-N841-AR
e-GeForce 8800 GTS
Part Number 512-P3-N841-AR
Core Clock Speed 650MHz
Processing Cores 128
Memory Clock Speed 1940MHz
Memory Bandwidth 62.1GB/sec
Shader Clock Speed 1674MHz
Bus PCI-E 2.0
Interface DVI-I, DVI-I, HDTV-7
upon registration
512-P3-N841-A3
e-GeForce 8800GTS 512MB
Part Number 512-P3-N841-A3
Bus PCI-E 2.0
upon registration
Article Viewed: 92489 times since 12/11/2007 7:00:00 AM
© 2012 EVGA® Corporation | Legal Info | Privacy Policy | Store Terms | All Rights Reserved
