Select Region:
Geforce 8 Series GPU’s
EVGA 8800 Ultra Black Pearl EVGA 8800 Ultra Black Pearl
The EVGA e-GeForce 8800 Ultra Black Pearl Edition takes extreme performance, and keeps it cool; ensuring the ultimate in reliability and overclocking. In addition to strict in house testing, this EVGA card features Superclocked core, memory and shader clocks. Innovative E-Flow technology can keep the card from breaking a sweat under extreme conditions.
Just ask Vince k|ngp|n Lucido. He was able to raise the bar and set the 3DMark 2006 world record at over 25,000 points with a pair of EVGA 8800 Ultras.
EVGA 8800 Ultra Black Pearl:
Black Pearl
  • Works with either or 3/8 water cooled systems
  • 100% testing to ensure quality, performance and reliability
  • Up to 30c degrees cooler!
  • Single slot solution
  • Made in Germany
Extreme Performance
  • An astonishing true 655MHz core clock
  • 108 GB/s of Memory Bandwidth
  • An incredible Fill Rate of up to 42 Gigatexels/sec
  • 3DMark06 World Record at over 25,000 points with two EVGA 8800 Ultras
Fantastic Features
  • Fully Unified Shader - Dynamically allocates processing power to geometry, vertex, physics or pixel shading operations.
  • DirectX 10 Ready - Completely unified and optimized for current Microsoft DirectX 9 and next generation DirectX 10 games and applications.
  • 128-bit High Dynamic-Range Lighting Twice the precision of prior generations for incredibly realistic lighting effects now with support for anti-aliasing!
  • 16x Anti-aliasing Technology Lightning fast, high-quality anti-aliasing at up to 16x sample rates obliterates jagged edges.
  • NVIDIA SLI Ready Up to 2x the performance of a single graphics card.
  • Built for Microsoft Windows Vista Gives users the best possible experience with Windows Aero 3D user interface.
All these new technologies found in the e-GeForce 8 series GPU processors allow the PC Platforms to experience high-resolution, high performance gaming, and stellar high-definition visuals.
768-P2-N888-AR
e-GeForce 8800Ultra Black Pearl 768MB
Part Number 768-P2-N888-AR
Core Clock Speed 655MHz
Processing Cores 128
Memory Clock Speed 2250MHz
Memory Bandwidth 108GB/sec
Shader Clock Speed 1663MHz
Bus PCI-E
Interface DVI-I, DVI-I, HDTV-7
upon registration
Article Viewed: 89711 times since 05/25/2007 5:09:58 PM
© 2012 EVGA® Corporation | Legal Info | Privacy Policy | Store Terms | All Rights Reserved
