Back To Top
EVGA GeForce GTX 1080 ACX 3.0 EVGA GeForce GTX 1080 ACX 3.0 Card Precision XOC VR Ready
The EVGA GeForce GTX 1080 featuring EVGA ACX 3.0 cooling has arrived. This new graphics card features NVIDIA's new "Pascal" graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
These cards also feature EVGA ACX 3.0 cooling technology. EVGA ACX 3.0 once again brings new and exciting features to the award winning EVGA ACX cooling technology. SHP 3.0 gives increased heatpipes and copper contact area for cooler operation, and optimized fan curve for even quieter gaming. Of course, ACX 3.0 coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU. Select EVGA ACX 3.0 models will even feature a 10CM fan and RGB LED, allowing complete control over the color from EVGA Precision XOC.
Standard Overclock Mode
Pascal Linear
Pascal Manual
Built In Automatic Tuning
Adjustable RGB LED
* Available on select models
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum “power target” takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX 3.0 coolers use more than 4X lower power than competitors allowing for better and more stable overclocks.
8GB of high performance memory running at extreme Clockspeeds giving you access to higher texture qualities in games and improved 4K gaming performance. Did we mention that this memory is running at an extreme 10,000MHz out of the box??!!
Looking for something even cooler? Achieve gaming bliss when paired up with an EVGA HYBRID or HYDRO water cooler.
COMING SOON
08G-P4-6386
EVGA GeForce GTX 1080 CLASSIFIED GAMING ACX 3.0
  • 2560 CUDA Cores
  • Base Clock: 1721 MHz
  • Boost Clock: 1860 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
  • Memory Detail: 8192 MB GDDR5X
  • Memory Bit Width: 256 Bit
  • Memory Clock: 10000 MHz
  • Memory Speed: 0.2 ns
  • Memory Bandwidth: 320 GB/s
Key Features
  • EVGA Double BIOS
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • NVIDIA GPU Boost 3.0
  • Microsoft DirectX 12
  • Vulkan API
  • OpenGL 4.5 Support
  • PCI Express 3.0
  • EVGA ACX 3.0 Cooling
  • Adjustable RGB LED
  • 14 Phase Power Design
08G-P4-6286
EVGA GeForce GTX 1080 FTW GAMING ACX 3.0
  • 2560 CUDA Cores
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • EVGA Double BIOS
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
  • 10 Phase Power Design
08G-P4-6183
EVGA GeForce GTX 1080 SC GAMING ACX 3.0
  • 2560 CUDA Cores
  • Base Clock: 1708 MHz
  • Boost Clock: 1847 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
08G-P4-6181
  • 2560 CUDA Cores
  • Base Clock: 1607 MHz
  • Boost Clock: 1733 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
08G-P4-6180
EVGA GeForce GTX 1080 FOUNDERS EDITION
  • 2560 CUDA Cores
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
EVGA GeForce GTX 1080 Comparison Chart
